rear blind
Mcdommo
Uk
C63
Hi All Rear window blind not working any ideas the car does come with this option but not working anyone had similar probs on a 2008 c63 ta
Did the blind wrk at any time you have owned the car?
If so, I'd start by checking the fuse for the blind operation. There should be a fuse chart with the tool kit or in thedrivers end of the dash fuse compartment.
Hi no I’ve only just brought the car everything else seems to work ok
Put your Vin # (all 17 letters and numbers without any spaces) into this website and you can see what options were fiited when the car was built.
You can get the Vin from the bottom left windscreen if the V5 isn't handy.
Mercedes-Benz VIN Decoder
Edit.....if you bought from the main dealer and the rear blind is fitted, get them to fix it under warranty.
Hi thanks for reply I have checked with them already and it is installed but unfortunately I brought the car private sale
