The AA are replacing a lost key on Monday and say it will take a good few hours to do as they need to remove the dashboard. It this normal and if so why?
I'll give them a call to find out why they need to do that
Yes it is correct (in a way) and he will basically remove your Key EIS (NOT THE DASHBOARD). No it probably wont take that long. He will be giving a bit of lee way in case there is anything our the ordinary that is found along the way. I just had a thought. If he is going to replace your actual electronic steering lock (ESL)module aswell aswell then yeah it would take few hours including taking apart a bit of the dashboard. Why would you want this done. if its getting done then good. Because if your ESL fails then the car will lose ignition and not start until the module is replaced with a mercedes one OR a simulator which is much less hassle in the long run. It DOES sound like hes just gonna remove your EIS key module tho and read it then simply add a key. It will show how many keys are programmed to it and will give an option to add another without having to delete any other keys (if thats what you want). If its a on the bench reader he has then EIS removed. Its not a biggie.I spoke to them and they said they need to access EIS for codes. Not sure if this is correct but will find out on Monday
