jamesmprint
After my door RDS door was jammed shut I finally (with great difficult) managed to remove the door card, drilled the rivets took the panel off and have just ordered a new lock mechanism.
Stupidly I hovered up all the rivets and filings and now not sure what size rivets should go back on. Anyone know?
Also when replacing the new lock will i run into any problems with coding it to the car or does this not affect this part.
Thanks in advance....now onto replace the FDS door actuator.
