m80
- Apr 26, 2015
- Location
- Derbyshire, High Peak
- Viano ex long, 651 2014. S211 646 2009 (till the Gov't drones blow 'em off the road)
The larger screw, lower forward, is a T45.
The smaller screw, higher rearward, is a T25.
Both behind push in covers.
Along the bottom are 3x pushins, with cross head plastic screws into those.
The lock button trim needs to be prised upward and removed prior to card removal.
The plastic bulge cover, over the heavy door stop, is just prised clear. Removal of the door stop is easy, but perhaps not required.
On the blind side, at the top, can be seen the plastic that pushes onto steel clips on the door. If cold this can be brittle. The photo shows one part of the plastic has broken off.
