Request for help: Enable AUX in COMAND NTG3...
rashdownonline
Brinkworth
S500; 2007; 5.5L V8 (W221)
Hello.
I'd be most greatful for any advice/guidence in how I can have AUX enabled within my NTG3 system.
I have a UK-Spec 2007 W221 S-Class (S500) with an NTG3 head unit. It also has the Digital TV unit with it. It does have bluetooth but only for the telephony integration.
I'm looking to implement a Carplay/Android Auto unit by Integrated Automotive Mercedes Benz NTG3.0/NTG3.5 (2007-2012) CarPlay and Android Auto Upgrade Kit - Integrated automotive UK (I Had one in my last car - a Merc E300 estate with NTG4.5 and it worked a treat!). The supplied wiring loom will connect to some pins (AUX) in the back of the DVD unit through which the audio will run.
I need your help in understanding how to enable AUX within the COMAND NTG3, please.
I’m about to have some work done by an independent MB specialist, and they have STAR/Xentry. He’s sent me this message just now:
"I currently can’t find a way of enabling aux. The videos I have watched have people commenting on them that it didn’t work or caused other issues with the Comand unit. The Mercedes workshop manuals do not list a way of doing it either. “
Might you have some tips/suggestion please that I can relay on to him? Any pre-requisites? Does the unit need to be at a certain firmware level? Or is it enabled via the Engineering Menu? If so, how?
Any help is greatly appreciated.
Thanks.
I have retrofitted AUX (audio and video) inputs for a MY 2006 V221. I was afraid Mercedes had removed the necessary menus from an up-to-date Star tool but I checked (simulation mode) and the options still seem to be present.
Does your workshop use a genuine tool? It still should work without the VeDoc option code route (which may not be supported today). On a "private" tools you have more options, either standard version coding or through development data (or "Erstellerdaten" menu). Vediamo then if all other options fail.
W221 DAS Comand version coding.jpgW221 DAS Read coding and change if necessary.jpgW221 DAS development data.jpg
View attachment 167774View attachment 167776View attachment 167775
Thanks - That's really generous and helpful. I'll let my tech know and see where it leads.
Thanks again. Appreciated.
Roland.
