Does anyone know the part number (and cost) for the wiring harness needed to retrofit linguatronic to 2005 R230 with MOST bus?
Thanks for any help!
Paul G
You need to replace the phone harness with the one for linguatronic + phone. Then you can either replace the MOST harness, or just use some short fibres to link it in.
You have to take all the panels and the back out and the left seat (to access the wiring ducts).
And you need a new column cowl, switches, and cover set to add the lever
Apart from that you need the linguatronic module and some screws.
Thanks Richard!
I don't suppose you know the part number for the harness?
Does the new column switch assembly plug into the existing 'socket' or is any additional wiring work required at that point?
Cheers
Paul G
