- Jan 21, 2005
- Location
- Mittel England
- Smart ForFour AMG Black Series Night Edition Premium Plus 125 Powered by Brabus
I'm posting this to help others who Google search whether a towbar can be retrofitted to an ML63 AMG.
A few weeks ago we took delivery of our new W166 ML63 AMG and having a towbar is essential for us, so before I committed to the car I checked the VIN or data plate showed the Gross Train Weight (GTW) meaning it's legal to tow, and dropped Tamzin at Westfalia an email to see if they've done one yet.
When we had a towbar fitted to our W164 ML63 AMG we had a bit of game to begin with, as pretty much every towbar manufacturer and every towbar fitter said it couldn't be done as the kit didn't fit the AMG or it simply wasn't type approved for towing, and was therefore illegal. Read more in this thread.
Last time, to make sure it went smoothly I bought the towbar kit from Mercedes, and had the towbar specialist they used to fit it. It fitted fine, and with the exception of finding the right relays it went relatively smoothly with help from Mercedes, Westfalia, and our very own Richard from MBClub.
Westfalia supply the towbars to Mercedes for factory fit and for the parts counter, so this time I went straight to Tamzin at Westfalia, who recommended a fitter who had installed the towbar on a W166 with AMG kit, which was Towcraft in the heart of the Black Country, not too far from me.
Westfalia warned that the mounting plate for the electrics would need to be "persuaded" (ie bent a bit) and sure enough it fit. Westfalia also supplied the integrated wiring module, again just as it would be supplied if you buy it from the MB parts counter, so much more simple this time around.
The integrated kit does things like illuminate only the caravans rear fog lamps when the switch is turned, and not on the car, so there's no glare reflecting back at the driver from the front of the caravan. It also adjusts ESP, disables rear parking sensors, etc. Clever.
So today, Towcraft installed the towbar:
The Westfalia part number is 313406 and here are the fitting instructions if you're considering installing it yourself.
So all in all even smoother than last time. Last time we were the first to retrofit a towbar to the W164 ML63 AMG or AMG kit, however given the popularity of the AMG kit on the W166 it was inevitable that it would have been done before on a car with the AMG kit, although we don't know if an ML63 has been done before.
The car is being detailed so I won't have it back for another week, so I have no idea how it tows. Once I have some photos I will update this thread.
Finally in case you're wondering whether the Performance Package affects the towing weights or type approval ...it doesn't, and it fits fine;
Thanks to all involved
- The bar/beam behind the bumper bolted straight on in place of the standard item.
- The lower bumper valance has a removeable panel so no need to trim or cut.
- After fitting the panel is secured with one 10mm bolt rather than 2 trim clips, as the second fouls on the 13-pin socket.
- The 13 pin electrics socket was fitted and positioned perfectly on the bracket welded to the beam, once the bracket/plate had been "persuaded".
- The integrated wiring module was plumbed in between the standard wiring loom and the 13 pin socket.
- The coding was done without issue, so the car knows that a towbar is fitted, and enables the electrics, etc.
