Facelift E320CDI estate struggles to start from cold. When it is below 5C (not -5C) it is a significant struggle for it. At current temperatures of about +10, just a slight struggle given that I press on accelerator as I start. After starting the "coil light" lights on and stays for about 1 minute. So the suspect is glowplugs.
Cheap error code reader reads: P0132 $07E8 O2 Sensor Circuit High Voltage Bank1 Sensor 1. This one appeared over the last few days as I cleared two errors a couple of days ago (the car had them for years even after services. Now just one - the above - but again the car had it for years).
I have heard on many occasions that glow plugs on CDI engines are almost optional. However at temperatures of about zero the car really struggles to start. Even at +10C if I disconnect the thick single wire lead that goes to the relay (I presume power supply) the car fails to start even after 10s of trying. So the experience is not too different to my old E300TD (now scrapped) which I run with just 3 of the 5 glowplugs for the last year of ownership.
Based on conversations with previous owner at the time of purchase he mentioned lots of similar trouble that he fully fixed. The history of repairs that seems to be relevant is shown below:
Date Mileage Description
Now 166
24/01/2013 114 Dealer, Replaced glow plug relay as dificulty starting from cold MA642 900 58 01 062423 / CONTROL UNIT
04/01/2013 113 Dealer, replaced O2 sensor MA003 542 70 18 Travel Sensor
31/05/2012 Supply and fit exhaust sensor GBP39
10/05/2012 97 O2 Exhaust Sensor replaced GBP195
01/05/2012 95 Dealer, replaced inlet port shut off motor
19/05/2011 81 Dealer, replace 6 glow plugs, including 2 broken off glowplugs
Is it likely to be glowplugs failure, relay failure or something else?
Most plugs are inaccessible. I can remove the nearest lead to the relay (presumingly the power lead). The second lead with many wires is quite difficult to reach but easier than all the glow plugs. If I get access to that lead will I be able to test how many / which glowplugs failed?
Given that at 81 miles when all glowplugs were replaced by the dealer 2 had broken off, does this mean that replacing them now will be a very difficult and expensive job? What sort of price should I expect for replacing all six?
Many thanks
Stocho
Now 166
Many thanks
Stocho
