S212 E350 PCV removal
BlueRubber
Reading, Berkshire
e350
Hi all,
Got a facelift S212 E350 and need some help finding the correct tool to undo the E10 torx bolts for the PCV.
There isn't enough room in there for a socket and I don't think a ratcheting spanner would have enough room to turn.
Any suggestions?
Thanks,
Small 3/8 socket with a wobble joint looks like it should go......
My E socket set is 3/8" connection. The E10 fitted fine. It was a year or two since I replaced mine. I can't remember if, once the bolts were cracked off, I then used a 1/4" ratchet and whatever the corresponding 6 sided socket was to fully undo, as this would provide more room.
But I definitely didn't have a struggle with getting the correct socket set on there. Maybe if the E torx sockets are 1/2" space might be an issue?
What size torx sockets do you have? 1/2" or smaller connector?
Thanks for the info.
I think the socket is 1/2" or 3/8"; I'll check
Didn't think of getting a smaller socket, I'll look into that.
I know this example I'm linking to is 3/8" available from Halfords, and I just use it as an example:
But most of my sockets sets have purposefully been purchased with six-sided sockets with rounded corners (as opposed to 12 sided, usually without rounded corners).
These 6 sided sockets also fit on the torx heads pretty well, although not as securely as a torx head!
So, once the torx head socket has loosened off the torx bolt, you can move to a 1/4" six sided socket of appropriate mm dimension. Probably an 8mm or something, easily found with trial and error.
Sorry if this sounds obvious, but there was a time when I started DIY spannering with my dad's really old (Halfords) socket set (which is still going strong), but that only has 12-sided sockets and I didn't realise you could get six sided, and stripped a few bolt heads off well-siezed bolts as a result.
Even with a 1/4" socket drive and using a 5/16 socket there wasn't enough room.
But I think an E10 ratcheting spanner would work for the bolt that is towards the centre of the engine.
The outermost E10 is recessed meaning the E10 ratcheting spanner wouldn't work.
Hi there, wondering if you ever solved this? I tried to get my pcv off my e350 cdi diesel coupe to change it yesterday. Managed to loosen the top bolt but couldn't get to the bottom one and gave up.
Really would like to change the pcv as I have leaky turbo and pcv seals limp mode mil light on in spite of swirl flap bypass.
Just to update this, I got them off with a little 1/4 inch drive socket set from Lidl with an 8ml socket to loosen then an e10 (I think) socket turned by hand. (Magnetic catcher at the ready lol). Very tight on e350 coupe the heat shield and plastic loops attached to it scraped my knuckles badly, ouch!
Now replaced the PCV and seal, the main turbo inlet seal and the green and black boost pipe seals. The green one was actually black and had been cut, I'm sure by the cowboys who did my last service, and must have removed it to replace the fuel filter. No wonder it came home with the check engine light shining bright!
