PaulMason
- Aug 24, 2022
- Location
- Teesside
- 2009 W221 S320 CDi, 2008 W164 ML 320 CDi Sport and 2004 R171 SLK 350
Hi, new to the site, though have been on numerous times to research an issue. My car is a 2009 S320 CDi, 154k miles. There is an intermittent fault where it goes into limp mode (I believe) and acceleration is very poor and it won't kick down (though will go through the gears on the paddles). The car had a recent gearbox oil service and was on Star, but no fault codes showed. I have also recently bought an iCarsoft MB V3 and no codes showing on that either. Having done a little research, one cause is sometimes a faulty throttle pedal potentiometer so bought a second hand unit and fitted it. This worked perfectly for about 150 miles and I thought the issue was resolved, but unfortunately the problem has returned. There is no consistency with when the problem arrives (in terms of miles, temperature or time).
My questions are as follows:
1) With the iCarsoft plugged in, is there a specific test I should run to seek out a code (its pretty new to me so I am not fully up to speed with how to use it properly)
2) In order to try and diagnose in the absence of a fault code, given there could be numerous causes, I was going to try on of the resistor plugs for the swirl pot next - its a relatively inexpensive way of potentially diagnosing if there is an issue with the swirl pot connector or motor or it being gummed up. Has anyone done this fix and are there any unintended or detrimental consequences of it that I should be aware of?
3) Does anyone have any thoughts or next steps with regards to the throttle pedal switch initially working and then seemingly not. Given the problem usually arises within 10-15 miles, I was hopeful that after 100 miles plus, across numerous journeys that it had worked? Is this simply I have bought another pedal that has an issue - I am trying to avoid the need for c. £120 for a new pedal which then may/may not work?
Many thanks in advance for any guidance shared
