Hi, I wonder if Anyone can help me with this.
I was driving the car yesterday and everything seemed normal and then suddenly the engine warning light came on and the car just died.
Thankfully it happened as I was turning into my road, the car was pushed home
The symptoms now are if I put the key in and turn to pos 2 the only lights which come on are ABS and a red triangle with a car in the middle, (no glow plug light, or engine light etc), I can NOT hear the fuel pump and the engine Cooling fan starts and runs at full speed and is quite loud, I turn the key to start and nothing happens no crank, just silence.
I went through most of the obvious fuses and cant see anything blown.
I connected it to my carsoft v12 diag kit and ibm t30 laptop I have, there seems to be no communication with 'ME' which is the engine control unit I am guessing? I have successfully used carsoft in the past on this car to find codes. I have checked the ECU connectors for corrosion, clean as a whistle.
I keep all my drain plugs clear because I know that water Ingres is a problem on this car.
My past experience with water problems in electrics is you get intermittent problems but this happened suddenly.
Does anyone know what powers the ecu?
Thanks.
Thanks.
