Chiprian
- May 6, 2013
- S320
Hi everyone,
I have a s320 from 2006, 82000miles. Recently the "check engine" light came up on the dashboard. I had the car diagnosed having a faulty DPF sensor. The car is on limp mode with no oomph at all. Since then when engaging the gearbox on D mode the car receive like a shock and I have to hold the break pedal firmly. Same shock happened when breaking, nearly to stop the car (when the gearbox change down to first gear). Is this normal to happened on limp mode or is something else that may cause this problem? Appreciate your help?
