Tubbasher
hi everyone I have a MB E220cdi w211 2007 the sat nav cd/radio and clock do not work does anyone know what controls these units and where it is situated on the car thanks
So the whole command unit is dead ?hi everyone I have a MB E220cdi w211 2007 the sat nav cd/radio and clock do not work does anyone know what controls these units and where it is situated on the car thanks
Thats correct there is nothing happening at all it started when the battery was draining over about two days , a mechanic said it was due to a certain unit which I cannot remember what he called but said he had disconnected but didnt say where it was situated and I dont want to take it back to him if I can fix it myself any imformation would be a great help.So the whole command unit is dead ?
Drivers side removable panel , fuse 28 , 15 ampSo the whole command unit is dead ?
thanks for your help will try as you suggestWould start with the fuse(s) maybe… check and re-seat the one(s) that relate to the problem. Did this on a Cayenne entire infotainment system went down and totally unresponsive to button pressing, restarting the car multiple times etc… checked a couple of fuses, reseated them and system turned back on as normal.
will try what you suggest thanks for your helpDrivers side removable panel , fuse 28 , 15 amp
Any joy?will try what you suggest thanks for your help
not had chance to look at it yet mate Ive got to work on it outside so waiting for a dry day, is the control for the sat nav etc in the boot do you know because the mechanic said he had disconnected a unit that controls all that is now not working be cause it was draining the battery overnight which is now ok.Any joy?
Won't it start draining the battery again ??not had chance to look at it yet mate Ive got to work on it outside so waiting for a dry day, is the control for the sat nav etc in the boot do you know because the mechanic said he had disconnected a unit that controls all that is now not working be cause it was draining the battery overnight which is now ok.
Ill try that I remember him saying something about damp on that side of bootNot sure what they have disconnected exactly and from where... could it be amplifier in left rear wheel well due to water damage if that applies to your model?
yes it more than likely will but at least then Ill know what is at fault and try to source one off the netWon't it start draining the battery again ??
