Sat nav for 2012 b class
MartinOxley
Blackpool
2012 b180
Does. Any one have a sat nav fits as stock as I have no modem to connect to sat nav comand presume that I have to get one for this purpose
Your car probably has the Audio20 system, with pre-wiring for the optional Becker Map Pilot navigation processor.
Check inside your glove compartment to see if there's a bracket there.
See also:
If that's the case, then you can buy the Becker Map Pilot unit either second-hand on eBay, or new from Amazon.
If buying second-hand, keep in mind that it might not come with the latest maps installed, in which case you will need to purchase and download the latest maps (€89 from memory).
On another note, the main issue with the Becker Map Pilot unit is that it was MB's entry-level solution at the time, and further more it will be obsolete in today's terms, given that it was sold as an option between 2010 and 2015.
Talk to forum sponsors www.comandonline.co.uk, they may have some better options for you.
Markj contact has been sent to comand online but awaiting their response
Markjay got bracket in glove compartment but no the processor box which inserts into this
Have a look here (or search on eBay):
Or see what Comand Europe have to offer.
