Pocahontas
I should add I know where the instrument cluster is lol but I can’t see any codesOk thanks will do later when I’m back home![]()
Hi it says service B1 in 240 daysYou can check on the instrument cluster in the car which service is due next. It will be an alphanumeric code e.g. B5 or B6 etc. Post it here and we'll tell you what's due.
I agree with you...The best way to take one out is when it covers B,A,B (because B service costs more) .
Also worth working out when gearbox service is required and spark plugs if it’s petrol .
What year is the car ?
OK, that makes sense as the car should have had an A service in 2020, B in 2021 and A in 2022.Hi it says service B1 in 240 days
I too was expecting spark plugs and air filter to be replaced at the second B service in year 4, but the W177 series is different: air filter and spark plugs are changed at 36-month intervals, i.e. on the second A- service, then the 3rd B-service, and so-forth. Brake fluid is still changed every 24-months, i.e. on the B services.That's a bit odd, I would have expected the car to need various other bits in year 4 (brake fluid, air filter, fuel filter or spark plugs).
1 is a brake fluid change.B1 is Service B with no additional items.
That's a bit odd, I would have expected the car to need various other bits in year 4 (brake fluid, air filter, fuel filter or spark plugs). I can only guess that the additional items have already been done in the last service (year 3).
Do you actually have a printout of the service history? If not, you can get one printed for you at your local MB dealership (bring the V5C in your name and photo ID).
Yes so it had a B service in 2021 which had an oil and filter change and brake fluid replaced. In 2022 it was an A service and says the air filter element was replaced, spark plugs replaced and oil and filter changed.B1 is Service B with no additional items.
That’s correct. See my post #27 above.In 2022 it was an A service and says the air filter element was replaced, spark plugs replaced and oil and filter changed.
Thanks I will take your advice and take out the service plan as I plan to keep it for a few yearsThat’s correct. See my post #27 above.
I had a 2 year service plan on my S63 which is now finished. Decided to take out a new one, on to Mercedes site. No difference in price if paying monthly or paying in full. Might as well go monthly. Filled up the form which was forwarded to Arnold Clark (Dundee). They will get in touch to set it up. That was 3 weeks ago. Obviously can't be bothered. Anyone else had this first class service![]()
It's not. Same process.But maybe it's different for AMG cars, I don't know.
I filled in the form at least 5 times and didn't get a single reply. Eventually had to go into the dealership to arrange it.It's the dealer. When you fill out the online form from Mercedes, it asks for your postcode, then flags up the closest dealer. You pick one & the form is sent to them & they will contact you.All Mercedes dealers around me, ie Dundee, Perth, Dunfermline are, you guessed it, Arnold Clark. They have nearly every car franchise in Scotland
Obviously can't be bothered. So if they are reading this, wakey, wakey( Was going to say something else but in this woke age will probably be locked up)
Just filled up the online form again. Let's see when my next post on this subject will be.![]()
The Dunfermline dealership is Eastern Western, the same as EdinburghIt's the dealer. When you fill out the online form from Mercedes, it asks for your postcode, then flags up the closest dealer. You pick one & the form is sent to them & they will contact you.All Mercedes dealers around me, ie Dundee, Perth, Dunfermline are, you guessed it, Arnold Clark. They have nearly every car franchise in Scotland
