SL400 2015
  • Thread starter Thread starter tanuie
  • Start date Start date
T
tanuie
Guest
Hi Guys
Pictures will follow, is the SL400 2015 is a R231?
Also could any give me the datacard, reg number YN15 UUM (by the way will be changing the number plate!).
Many thanks
Recently bought fab" sl400 black with porcelain nappa.
I hear a faint matalic 'pinking' sound coming from mid driving side.... took it in, spent an hour out with MB technician who then spent time having a good look. Said it was nothing sinister but offered no explanation. Anyone had similar?
Metal expansion/contraction when hot ? From the exhaust
Hmm.... possibly that W1ghty. Maybe exhaust flap? Not sure where that is .... I shall try and record it and post it here. Doesn't make noise in neural only when accelerating. Most noticeable when pass a wall as you here it on bounce back.
I think driving next to a wall always gives a false impression of engine noise , because normally you hear engines from the cabin or exhaust as you are surrounded by noise absorbing padding .
Then you drive by a wall with your window down and you hear the noise from under the car bouncing up and think that sounds dreadful , there must be something wrong
Let's see if I can get to the bottom of this mystery sound
Thank you but have checked tyres and they are clean.... will try recording sound today and post it here if poss'
