SL500 ABC and red battery light displayed
Mercedeschris
Bolton Lancs
2010 S207 350 CDi and 2005 R230 SL350
More issues on my 2005 SL500. I've posted things previously about not cranking over, I bought the car as a non runner, replace ESP ECU and it now runs fine.....But I've now got the "three Amigos" on dash...ESP ABC and red battery light. I have access to a friends STAR and got P202F-004. 5B13. B1106. B1132. Anybody had anything similar? As always any info greatly appreciated. N82/1 looks brand new, as I see they are an issue...not least setting on fire....Don't know why MB have got away without recalling the early R230s. Salvae yards have loads for sale with boot fires.
Cheers
Sorry if I'm stating the obvious, but a dead battery will chuck up many faults.. have you tried a new battery front/ rear... red battery warning suggests its dead. when my consumer battery went dead.. all faults were related to it.
Thanks John.
I've replaced the consumer battery and the starter battery is only a month old. This battery light issue seems endemic in these early R230s. There are loads of info on web with owners having this fault. I am trying a few ideas today after pouring over the wiring diagrams for hours yesterday...
Attached is a copy of a pro-forma invoice that was in the car when i bought it.....
I'll also repeat the obvious, the R230 is infamous for flattening its consumer battery (but not its starter battery), when left unattended for 4+ weeks, especially if the battery wasn't fully charged when it was parked up. SL's are often used as 2nd car runabouts for weekend or summer use, so seldom get a chance to charge that consumer battery "on a run."
Once that battery flattens, it can kick off a variety of false error messages across a range of sensors. An electrician knows how to check and dismiss false warnings. Dodgy error messages are endemic across all modern vehicle electronics - not just the R230, nor MB. Those warnings are there for good reason, but they can lead you down dozens of false trails.
The easiest, and ecologic, is to stick the consumer battery on a battery conditioner, which is different to a "charger," and charge / condition the thing back up again, rather than replacing the battery.
But, and here I get to my real point, if you've got electrical problems, use a car electrician. They're cheap, don't have MB main dealer overheads, and know more about electrics than any willing amateur will ever be able to take in.
One thing I did find with my car was a faulty PSE pump literally sucked my new battery down to 4v as I stood there trying to trickle charge it.. worth pulling the PSE pump fuse 20a behind the drivers seat in the storage bin... and seeing if that changes anything.. when this issue happened my dash went red with warning lights.
