Hi guys i am having some problems with my 52 plate SL500, i bought it from Mercedes Benz of Wakefield as an approved car in 2006, 1 week later the pump controlling the central locking and the roof had to be changed under warranty, the automatic gearbox was changed, the car has recently had the drivers side ball joints and the hydraulic suspension unit changed (2600 pounds!) and the engine mountings changed last month as well, and now my garage is saying that the engine is miss firing due to faulty HT leads and it needs 16 new leads otherwise the cats on the car can be damaged? they only found out about the misfiring as they asked me if the car rides smoother since the suspension work, i said the same really, but the car in neutral still occassionally gives a small quiver, but it has always done this since i bought it from merc wakefield, and when i mentioned it to merc epsom and also AMC neither garages found any problems with the engine? can any of you guys shed some light on this as i am getting fed up of spending 100's of pounds on the car literally every 3 months since the warranty expired 2007!! thanks for your help!!
