Sl55 2003 servicing
Rudycob1
Doncaster
SL 55 AMG
I will be servicing my car for peace of mind service and wish to get your experienced recommendations:
What are the best spark plugs to use?
What engine oil do you recommend?
What transmission oil do you recommend?
What differential oil do you recommend?
Can anybody confirm the engine oil filter part number?
Does anybody know the torque settings for:
Intake housing! I need to replace the gaskets.
Transmission pan bolts?
Spark plugs?
Your local motor factor or main deal can supply the correct parts based on your registration.
The spark plugs can be Bosch or ngk there are 16 and it's a big job
Best oil is 0/40 Mobil 1 think there is around 8.5ltrs and there are 2 drain plugs!
Transmission: dextron 3 or Mercedes oil plus a filter and sump gasket (bolt torque 7nm)
Diff oil use to be 80w90 but I think people use 75/90
Hope this helps.
