gavstoke
Hi everyone,
My 2003 SL600 has developed a problem with the rear abc suspension.
Firstly, at the recent MOT the n/s rear shocker was put down as an advisery due to 'slight misting', which after reading some old posts on here didn't worry me too much.............for now!
but now the ABC warning light has started to come on along with 'visit workshop', when this happens something is changing slightly at the rear of the car and it starts to pull to the right, when I pull over and switch off the engine then restart the car, it levels back up again and off you go, this happened once ages ago, but has now started happening more often.
I took it to the local merc specialist and he had to drive it for 20 miles before it happened, then he has said it is showing as a fault in the ABC sensor in the o/s rear shocker, it appears that the sensor cannot be bought separately, so guess what....................looks like I need a new shocker @ 1051.00!
Clutching at straws here maybe, but does anyone know of a less lottery win busting fix for this issue? or does anyone know of a uk based repair company that can overhaul them( like Arrnot industries in the states)
seems mad that you have to replace the whole shocker just because a sensor is faulty?
btw the body rises and falls perfectly when you press the button.
any help would be much appreciated, before I have to choose which child I have to sell!
cheers
Gav
cheers
Gav
