SLK55 problem...
BenzedUP
London & Surrey.
NA
Not sure if anyone has experienced this before;
Hardly getting any air coming from my SLK55, my climate control works fine, I've set it on high but there's very tiny amount of air coming.
There was a noise coming from behind the dash last month when I turn the climate control on but that disappeared however now there's hardly
any air coming out from the vents..
The car is going for 'B' service at MB dealer in a few weeks so I'll probably ask them to investigate.
Any ideas what the issue is please guys?
Cheers,
Jo
I believe that'll be the resistor pack for the fan, when it goes the fan only operates (if at all) on a low speed, they are not pricey to buy but I have never changed one so not sure on the labour.
Its correct, i had the same problem, that card of the vent it's in the middle of the fan
BenzedUP said:
Thanks Guys. Do you know how long does it take to fix?
Its fast, you only need to quit the fan and change the card, but if you do it In a Mercedes mecanic shop they will want to change all the fan with the card
