smoky engine
stephen1980
grand voyager 2.5 diesel
i have had new injector seals on my 2001 2.5 diesel voyager,since they have been done my engine now throws out alot of diesel smoke but it runs fine,any ideas i habe used a cleaning adatif and no change.
This may not be the best forum to ask this question on....the engine you have is a VM Motori diesel engine.
Did they centre the injectors correctly when they put them back in....if they are slightly off centre the diesel spray from the injector will not correctly hit the middle of the piston which can then cause some of the fuel to remain unburnt....hence black smoke
