Hi all, I was doing an oil, filter and spark plug change this evening. All going well until I snapped the last plug off, leaving just the thread in.
The car is a 1988 W124 E230 Estate.
Should I:
Try and drill it out / helicoil
Try and find a secondhand head
Other?
Hi merkyworld,
Sorry to hear of your dilemma.
Firstly, when you say that the spark plug has
"snapped off", are you actually saying that the remainder of the plug came away with the electrode and the heat insulator tip intact, thereby only leaving the threaded section within the cylinder head.
If you are, then you may be very lucky and get away with just using an appropriate "easy-out" . If not, then you really do have a problem.
Do not under any circumstances attempt to drill it out whilst in situ, the results will only prove to be catastrophic. If any of that metal swarf or indeed the metal filings does in fact get lodged between the piston and the cylinder wall, and it surely will, then you will destroy the cylinder liner, thereby creating loss of compression and piston blow-by.
Your only and the correct solution is to remove the cylinder head and do the job properly, and at considerable cost to you if you are not able to do this work yourself.
The cost of the parts alone, head gasket set, stretch bolts, head skim, etc. would prove to be quite expensive. If you are not able to do it yourself, then any competent mechanic/garage would do this for you but I would think that it will run into many hundreds of pound to rectify.
With the greatest respect, you say that the vehicle is in fact a 1988 model, I would also consider whether such a repair would be deemed cost effective given the age of the vehicle.
A helicoil is normally only used for the purpose of stripped threads, even then, the head should be removed even to do this job properly. A secondhand head may very well be an alternative solution, but even then you would still have to skim the cylinder head and possibly overall it - decoke, new valve seals etc. This alternative would prove to be even more expensive because you would have to source such a cylinder head and the overall costs in doing so.
Regards,
Dash1
