I don't think so (although my experience is from a different Comand unit). But can you explain why you would want to change the speed dial settings from Comand instead of doing it from the phone? I assume you don't want to change this very often.
Yes, COMAND can access the speed dial numbers but IIRC it has a rather strange way of allocating those positions.
I don't have my handbook handy at the moment so can't check, sorry.
Hopefully some one else will have the definitive answer.
Meanwhile, have you tried pressing a number on COMAND? On mine #1 key has the voicemail symbol...
That makes sense, I thought you wanted to access speed dials to edit them, though accessing for phone calls was obvious (which it isn't, like early W221 cars are lacking that feature and only come with a Comand update). Sorry for missing your point but luckily others were able to help.
