tcourtneyvincent
Hi there
Hoping someone techy can help me out.
2008 Sprinter 311 engine 646
Goes straight into limp mode (turbo deactivated) from the moment I turn the engine on.
Can get the actuator to move on and off in live data (I have a Icarsoft MB 3.0) so doubt its that.
Getting the following codes all "current and historic" with ignition on and engine off.
010501 B5/1 (Boost Pressure Sensor) - The Signal Voltage Is Too High
010502 B5/1 (Boost Pressure Sensor) - The Signal Voltage Is Too Low / Charge Pressure Is Too Low
010504 B5/1 (Boost Pressure Sensor) - CAN Signal Faulty
010508 B5/1 (Boost Pressure Sensor) - The Atmospheric Pressure Between Component B5/1 (Charge Pressure Sensor) And Component N3/9 (CDI(Common Rail Diesel Injection) Control Unit) Is Implausible.
Have replaced the boost pressure sensor and still no luck.
On live data the boost pressure sensor is reading a fixed 800hpa or Millibar, doesn't shift from this figure from engine on or off, under load or not, which from research I believe it reverts to when signal is implausible.
If I unplug the turbo actuator and plug it back in while its running I can trick the turbo to become fully engaged, which under load the charge pipes go hard so the turbo is functioning.
This is a camper and I have been on the road towing by business around so i'm totally stuffed with it out of action!
Many thanks in advanced!
