nemesis0124
Just after some advice, ive recently bought a sprinter 206k miles 2.1 cdi 2007 that doesnt run as a project. The guy i bought it from told me the it just cut out and would not start (no idea if thats true or not) Fuel is getting from the tank to high pressure pump but the rail and injectors are dry. Scanned with a generic scanner an only persistent code is p1995 which seems to be glowplug related. Tested relay which works and changed the glowplugs. Wondering which is most likely suspect? High pressure pump, rail, crankshaft sensor,cam sensor or something else. Thanks in advance
