coventrysimon
- Jun 29, 2016
- ml270 cdi
Hi, my 2003 ml270 is having starting problems when warm. Had green flag out but by the time he arrived engine had cooled and started first time. He said change fuel filter which I did and also the air filter.went on holiday and covered 700 miles with no problems until I arrived back in Coventry and then had green flag out again. He started the car by spraying brake cleaner into air intake and it started,but no idea of fault. I think in the past it has had injector fault as seems a bit black around the injectors. Could it be an injector or should I start with crank sensor?
Any help would be great as these hire cars are getting expensive
Also when trying to start the rev counter does move
