Clarkey191
Hi.
I have a 2011 ML350 and are encountering an issue on trying to start car.
The car locks and unlocks fine with the fob, however when I put the key in and turn it none of the warning lights come on the dash. If you then turn it into the start position it will then light up the dash and the engine will turnover and usually start, but this does not allow the preheat to work so the car turns over for quite a while, the car battery seems fine and everything else works fine.
Any help would be greatly appreciated!
