I've never needed a hammer, try and make sure the adjuster lever is being operated at the same time and hit it quiet hard in the direction it won't move, if it fails, hit it again
Bang it hard enough and you might set the airbag off
Anyone else encountered this, the steering wheel adjustment has stopped working. I have a 15 plate E Class with Memory seats but the wheel will not budge from the highest position!
If it's the same as a C class extend the steering wheel all the way out, then use the up/down lever while pulling up & down on the steering wheel, It will eventually go up & down on its own when you use the up/down lever.
