Steering wheels off-line........ Why?
wheels-inmotion
Hemel Hempstead
Daily hog is a Vectra
The most common complaint after front wheel alignment is the end position of the steering wheel this is a visual indication that
1: The workmanship was poor
2: The equipment is inadequate
3: Alignment was never the real problem
4: The manufactured cars axle is miss-aligned
Nearly every alignment test in the World is sold to the customer by the shop based on visual wear on the tyres at the end of there life, inevitable history of past alignment problems would still exist on the face of the tyre, born from this visible wear and potential loss of the new replacements a customer could assume a problem still exists and is easily sold.
Taking 1 to 4 here are my thoughts)-
1: No legal responsibility is required to ascertain the understanding of the technician who sets the direction of your £50.000 (theoretical) car with the new £500 front tyres, most common is a 'drive by' smattering of knowledge that involves undoing of nuts and about ten minutes additional time whilst you pay the bill, (so knowledge maybe why)
2: There are many machines on the market that promise different levels of alignment, most common is 'front wheel alignment' this form is the most damaging and by today's standard only suitable for the horse and cart, can i remind you that the car has 'Four Wheels', (so the equipment maybe why)
3: With the magnitude of problems expressed though the tyres during their life span it would be easy to assume alignment is to blame. Current issues with the Geometry or the cars health in general will cause untold affects toward the tyres and handling, this does not dismiss the fact that 'at the time' the alignment may be incorrect, (so maybe the car is why)
4: There are occasional manufacturing reasons that deceives the operator, this is unusual and depends on equipment, this is most times geometrically undetectable (so maybe the construction is why)
Taking all possibilities into consideration the common denominator is the Thrust Angle the cars true centre that most angles depend on as reference......simple as that!
What's this "thrust angle?"
The thrust is simply the centre of the rear drive wheels are going? All reads a bit odd but the front wheels don't actually know where forward is....
For a RWD the forward reference for the front wheels is the rear thrust angle, or in layman's terms the exact centre of thrust. This point of reference is where the front wheels are tuned to directionally. If the likes of pants fit only use the front wheels to establish front toe they have no idea what direction the rear is going....
Example, here are the rear wheels \ \ and here are the front / /, for the car to drive correctly the rear wheels need to be | | at this point the perfect thrust reference centre line needs to be established, once done the front wheels have a reference centre line to align to.
I bet every member here that if you asked the alignment shop what they are aligning the front wheels to they would all the "each other"..... Wrong!! They should be aligning the front wheels to the thrust position.
Be wise peeps, fast fit don't know ****.
You are totally right .
Do you know any good place where I should go for a good wheel alignment.
I just arrived in England and I had a terrible experience with ats euromasters this week.
The author of the post above is the person in this picture:
http://www.wheels-inmotion.co.uk/wheels-alignment.php
You can book an appointment through their website.
