Hi Guys,
I've had this mis-hap happen to me exactly 4 times since i've bought the car (1 year and almost 9 months), but yesterday it was quite severe and i really want to know why its doing it.
Basically I was giving it full throttle in first, and changed into second. No problem so far, now as i'm finishing 2nd gear and changing up into third, i have a feeling i did it slightly earlier then when i pressed the clutch pedal, it came half way and then got stuck! And i was stuck in second gear all the way home!
No matter what i did, no matter how far i pushed the clutch pedal in or out the stick wouldn't shift out of second. The stick itself still had some movement, but if i tried to reselect first or second it would feel as if its blocked. Even if when moved the stick around, the car was still driving in second gear.
Now when i think about this, i can only blame two things really; the gear selector itself (maybe the linkage to the gearbox isn't up to scratch), or the clutch release bearing? or it could be the gearbox just showing signs of wear?
What do you guys think?
Note: The previous 3 times its done this was in 3rd gear. when i'd try to change out of third, it would come half way and then stay there rendering the selector immovable. I really cant figure this out!
