As said , it's a 20 year old car. It is unrealistic to expect any support from the manufacturer.
I'll give you £20 for it as the value of these has dropped considerably. Apparently there's an issue with subframes![]()
£5 from me - the SatNav maps will be out of dateI offer only a tenner... Apparently there's also an issue with Opal Red![]()
He would owe ME money then!Luckily it doesn't have the M271 engine.....![]()
Now I’m depressed having a 2012 E class which is not only affected by these sub frames but also has the M271 EVO engine… plus I can’t find a front passenger seat pad sensor.. I thought I knew what I was doing buying this 2 months ago![]()
Too many Equity members (the union for ****** comedians!!) replying, she may be Fire Opal Red but the paintwork, other than the 2 small areas in the front bottom corners of the front wings, is perfect - but whether that's original or after recall and respray I don't know as MB North Wales (original supplier and servicer) will not answer me! There were a number of problems (documented in the history file I put together) when I bought her, all sorted, and more recently a transmission sump small leak also sorted (new sump, gasket and sump plug on the transmission) so mechanically she's in top shape and everything works as it should. Can't use her ATM as wife is crocked so will not go out at all, so as S204 is on the driveway (SLK in garage on battery conditioner as usual!) I just use the S204 if I need to go anywhere, not had a weekend pleasure jaunt for 7 weeks now despite all the lovely weather. Road fund renewal arrive a couple of days ago, due by end of month, £430 for 12 months! Making me again question the justification for having 2 cars, but although the S204 is a very good car, I did not work all those years to only drive something practical, especially as I am used to the pleasure of driving a Porsche 968 and even the compromise SLK!OK, final offer.
£50.
To me that is!![]()
Cost will vary depending on where you are, who is carrying out the work and any other remedial work required. Have you not asked your dealer?I have a service agreement with my local MB dealer, and a the last MOT the inspector pointed out the rust on the rear subframe. The service manager assured me that MB would replace when the time came at fitting cost only to me. So I'm concerned reading this. Does anybody know what the full cost of replacement would be?
Sorry OP off topic but this point interests me, would this error message on the dash cause an MOT failure?I also need a front passenger seat occupancy sensor....might just end up fitting a bypass module.....won't change anything except I won't have to see that message on the dash everytime I don't have a passenger in the seat.
I looked at the bypass but not sure, on the other hand, the pad sensor is £285 plus a MB specialist to fit it for £150 makes it rather expensive for what it is.
So would the front passenger airbag never deploy with that error message present?
If so it’d be worth to fix it to protect the passenger.
However, If the airbag will always deploy even with that message present I could accept that if it passes an MOT.
From my Indy the subframe is £650 odd plus vat, I can’t remember how much the rest was but labour for doing the subframe, airbag and brake lines (it seems likely you’d need brake lines anyway when doing the subframe) is 7-9 hours. The airbag likely makes no difference to the time. So it’s the labour (fitting cost) that could make the dealer more expensive even if they pay for the subframe itself. Depends on the dealer vs Indy rate. In my case I also factored in convenience as the car was already at the Indy.I have a service agreement with my local MB dealer, and a the last MOT the inspector pointed out the rust on the rear subframe. The service manager assured me that MB would replace when the time came at fitting cost only to me. So I'm concerned reading this. Does anybody know what the full cost of replacement would be?
It does seem a bit daft they make the transmission case out of magnesium and then make the subframe out of baked bean cans.
