- Oct 4, 2019
- Location
- Guildford
- E250 Avantgarde Estate, Alfa GTV V6, Vespa, Ducati, many bicycles...
Morning, learned collective of the forum, wonder if you can help?
On my way out to get some softener salt i drove through a shallow puddle that was obscuring a small speed bump. It was just before a junction so i was going slow anyway, maybe 10mph but it was enough to give a slight jolt. Certainly ive hit pot holes that have been way more severe! But then suddenly the steering went very heavy (and actually required a lot more steering angle to turn - i guess this is due to the the variable rate?). I was literally 300m from home so thought id limp back, then after about 10 seconds i thought i heard a motor buzzing noise and the power steering gradually came back. Now it seems fine. I checked for any obvious leaks and all looks good, the fluid level is on the min mark for cold which im assuming is ok, as id only driven about 400m each way.
My concern is what could cause it? I thought maybe the slight jolt caused a connection issue, or the fact both sides of the car would have received a slight jolt could the fluid cavitate which caused an intermittent loss of power?
Any ideas? Is there a particular fuse/relay/connection i could check?
Many thanks!
Many thanks!
