aka$h
The revs when in idle initally surge from 500-1500rpm, and settle down after 30 seconds and will then only be between 500-700rpm. This is with a brand new MAS, prior to changing it the problem was not as bad, it did not surge so high initially but the problem was still present.
I very much doubt its a faulty MAS, I did try the old one on again and the revs do still surge but only form 500-700. I think this may be as the new sensor is giving a more accurate reading, but the underlying is problem is still present.
Anyone had similar problems?
Cheers
Cheers
