- Feb 8, 2007
- Location
- Portsmouth, Hampshire.
- E55K SL500 E250X2 Smart44 Brabus Track car E450Cabriolet X350 Pick up
Olly - did you have to replace the ECU for this swap?
Not telling.....
Not telling.....
I'm guessing then that you dont need to.
The timing will be the same I guess, may need a bit more fuel/air I suppose but a simple remap could achieve that.
Same coolant pipe as yours. No issues with the trans cooler either.
Starter issue was overcome easily.
SHE RUNS!
I can't do a sound clip as I don't know how.
We have a very slight missfire to sort too.
Maybe the E55 uses a different starter motor setup to the CLK/C M113 setup, perhaps due to the steering setup being different on the W210 chassis (?)
