Thoughts On This ABS Fault?
sledlife
Cheshire
W204 C350 CDI
Hi, I've had a fault recently which is the ABS and Run Flat indicator inoperative one, which I understand is often down to a faulty ABS sensor. I've taken my car to the local garage and they said they can't get a specific fault reading, just the following that has been thrown up. They said they can't get any further info as they haven't got the tool to get into the ABS hub or something to look into it further?
Would the following indicate a faulty ABS sensor, or possibly something more? Thanks
It looks like it is the front right ABS sensor that is the problem - but could be the sensor itself, wiring or could even be the reluctor ring or dirt/rust around the ring or the sensor or the surface that the sensor mounts to. Needs a thorough visual inspection before deciding to buy a new ABS sensor.
