TID file help.
Druk
Gone but not forgotten - RIP
Not far from Edinburgh.
2011 S212 E350CDi. 1981 R107 300TurboDiesel.
So I have a Panasonic TZ30 and took a short movie clip which I was hoping to load to YouTube. The computer sees a AVCHDTN file which then translates to a TID file which Microsoft wont recognise. If I Google the thing it says my registry is corrupted and needs fixed. I have a registry cleaner and that's been run but has no effect on the file. Panasonic are no help. :dk:
Any ideas folks please?
forgot to add. Windows7 and IE11 and AVG.
thanks.
Thanks for the help Graeme. Unfortunately it didn't work, however I think you may be right in the 'folder' assumption.
So the next trick is I've been into the camera settings and downgraded the format to MP4 which seems to have done the trick as far as getting stuff off onto the PC. All I need to do is re-record the short clip I did yesterday.
All will be revealed later...;)
Cheers.
