2010 E250 Estate OM651
Hi again,
This car would break my heart if my expectations hadn't been lowered so much during my ownership. So I accept that bits and pieces fail and break off after a certain age.
So I was cranking and cranking the engine this morning and no ignition and then smelled diesel. The hose as per photo had torn and diesel everywhere......
Ideally I will trim off the frayed edges and reattach the hose (having lost 2cms where it broke). I have a new mb clic clip for it.
If that does not work and because I don't fancy stripping out parts to access where the other end of the hose attaches, I might need to cut off a section and join another section of new 8mm hose. If so, what size joiner is best for a snug diesel proof fit with the help of a couple of jubilee clips at the joint?
Also will the cranking I did mean I need to purge the system to draw fuel up from one end?
Thanks in advance,
D.
PS In a previous thread I had weeping form the same place so maybe I should have expected the hose might tear,
Hi again,
Thanks in advance,
D.
Fuel hose weep | Engine
Hi, OM651 2010 E250 WDD2122032A... A while ago i had a weeping fuel hose and i replaced the correct mb clic clip (see blue circle in the attached image) and that fixed it. Unfortunately, the weep has returned. It is less obvious. Ther hose has some impression marks on it from years of...
forums.mbclub.co.uk
