Had my clk320 cab(2002)gearbox oil/filter changed by Tony Purslow(guildford) in december,they offer 40% off of labour & 15% off of parts so if you are not sure/happy about doing it yourself then get a specialist/indi to do itHow do I check my transmision oil?
CLK 320 1998
Want to do a full check over and change any oils that need doing. I cant find a dip stick for the gearbox?
Think you will find there isn't one fitted. There will be a tube with a cap on somewhere near the bulkhead - you can get them off E-Bay or ask nicely and someone near to you may be able to lend you one! I take it this is an auto? Has it done more than 60k? Ever had the ATF changed? If not, then you would be best getting it changed!
ATF - Automatic Transmission Fluid - if it hasn't been changed, get it changed! These boxes were originally 'Sealed For Life' but not anymore.... Will cost roughly £170 from a good indie, £300 from MB.
A lot of the MB's have a 'learning' gearbox which will adapt to your driving style. This can be reset by either disconnecting the battery for 20-30 minutes (not recommended if you don't have the radio code!) or by the following procedure -
1) Ignition key to Position 1
2) Press accelerator pedal to floor and count to five then release
3) Turn off ignition but do not remove key
4) Wait minimum of two minutes then drive car as normal.
You should feel a difference especially if the previous owner 'drove like a granny' lol!!
A proper ATF change with the proper Mb fluid including a filter and gasket from me is £165 inclusive.
Expect to pay around this amount. £60 is way too cheap to be using the proper oil. Its nearly a tenner a litre.
