goodster77
- Feb 1, 2015
- ML 320
2000 ML 320 was stuck in limp mode (no codes) auto gear box indicator showing yello box ( no P, N, D etc.. ) (no other faults - selection fine)after lots of research plummed for replacing gear selector. Order part fitted - success !!! took for spin no problems tiptronic also fine.
Got home - back into park.
Issue !
Stuck in park. After multiple attempts now always sticks back in park - need to use manual lever overide.
Was wondering if i could replace the PCB of new with my old as think this is a problem but cant get it off...
Is their something else I'm missing ??? Do I need to reset post gear selector change ?
other things to check ? Wifes car .. spent a day on it now and feeling the heat for the school run tmrw !
Issue !
