Transmission noise?
turboGT
Mercedes only!
Good evening,
There is a sharp noise (like as if a rock stuck in the brakes) coming from the transmission.
I changed the transmission oil but the noise is still here.
Does anyone know what it might be?
On what conditions does your transmission gives u vibrations? Is it while changing gears?
Hi, there is no vibrations and the noise occurs as long as the wheels spin (even in neutral)
When I apply the brakes, the noise is still here.
Any ideas? Thanks :)
What car do you have?
On some models a clip holding the handbrake cable can break, allowing the cable to rub on the propshaft. Could this be what you're hearing?
Top tip:- Put your car model and your location (nearest big town will do) in your forum profile.
Actually, I noticed that this noise occurs after hard driving or after a long drive.
Any ideas ? :(
U said u hear noises even in neutral! Something must be creating a contact between two surfaces from any moving part. Just try to spot where the noise is coming from. Then it is easier to diagnose the fault.
