TSU Reset - Starting issue?
SBD762
Exmouth
AMG SLK55
Hope I'm in the right place. 2015 R172 SLK55 AMG. Starts on the button! no hesitation, bursts into life as the key is turned.
Did a recent TSU Gearbox reset, no major issues, However the car is a "fraction" "hesitant" on start up. it no longer "bursts" into life, probably 1/2 second (or less) crankshaft turns before cat fires up.
It drives very well.
Have I messed it up? Is tiger a fix? or maybe crankshaft sense failing?
All advice gratefully received.
Regards
Steve
Not sure if that kind of reset would affect the crank time, however it could be possible.
The car is self adapting so should relearn everything in a few hundred miles.
If it’s still the same after that kind of driving then it’s more likely an issue with something other than the reset.
A good diag might be able to to certain resets like rotor adaption
Ironically, after a period of time , it has settled down and starts as it used to, thanks , Steve
