Plasterers bucket full of hot water, dash of fairy liquid and a dirty grouting sponge.![]()
I hope no one takes some of these serious!
If they do, they deserve it![]()
It doesn't take much longer once set up. Shampoo in one bucket clean water in the other. Grit guards if you like. Clean the mitt/Sponge/cloth in the water bucket then into the wash bucket , wash the car and repeat. Rinse with a hose/jet wash as usual.This may sound daft, but could someone explain the two bucket wash to me.
[emoji106]
That’s great...thought I should give my black car the chance to be swirl free, going forward.
I'll probably get corrected but...
That way you're never putting wash that contains the rubbish you've washed-off back on the car, and it should all collect in bucket 2.
- Clean bucket that has your wash in.
- Dirty bucket that you rinse your sponge/microfiber cloth off in.
I'll be honest and say that I don't bother with this, but I do use one of those grit-guard things in my bucket.
With tongue now removed from cheek, I would add that wash pads are actually superior to wash mitts. The reasoning is they produce less pressure on the paint surface than a wash mitt. With your hand inside a mitt you have halved the distance to the car and consequently increased your application pressure and thus the abrading power of any grit particle accidentally trapped in the mitt. Many mitts also come with rough elasticated cuffs with seams which could accidentally contact the paintwork. Have a look at this wash pad if you want to see the pinnacle in natural lambswool pads:
