![Confused :confused: :confused:](https://cdn.jsdelivr.net/joypixels/assets/8.0/png/unicode/64/1f615.png)
the other is a bit strange it seems slightly down on power but starts fine drives ok but if you stop it, it will not restart for about 20 minutes it turns over fine but will not fire this has me struck.
both have had fliters changed feed pipes , injectors tested the frist one comes up with fuel pressure faults but as we know that could mean anything the other has no fault codes at all
please help if you can
regards graham
