Tyre pressures..
Carrsey
Between a rock and a hard place.
E280 CDi Avantgarde
Anyone know the correct tyre pressures for my car..
CLK270 CDi but it has the bigger AMG wheels with 225/40/18 front and 255/35/18 rear. Or do the different size tyre not make a difference to the pressure thus just being standard inflation..
Just use the standard pressures, but if you are using, as you are, lower profile tyres, try using the lowest of the 2 pressures as found on your filler cap
