shorif2000
Hello, I have a w220 2003. I have been made aware that the NOx level on the v5c need to be filled in for this vehicle to be compliant as I don't have anything there at the moment.
This is response from [email protected]
I have asked them again
I sent email to tfl [email protected]
I have also sent email to [email protected] who I believe are in Japan
I also filled in contact form for Japan Land Ministry and Tourism.
Does anyone know if this is possible to solve?
There is a company in London that tests older motorbike vehicles to prove they comply so why this cannot be done for cars as well?
Unfortunately, your S500, [], was manufactured for the Japanese market in 2002 and therefore wasn’t tested to the Euro standards that apply to European cars.
The Japanese market have a very different set of standards that they require their cars to be built to.
Can you please provide me with a CoC or a official document with NOx level for my vehicle which i can then use to update the V5C
I have vehicle [] which is a Japanese import of Mercedes benz s500 L 2003 model.
As i understand you only use year of uk and eu model vehicles for compliancy check which is incorrect as this excludes the whole Japanese market.
Japan confirms to stricter standards and i would like to know
1. How you plan to incorporate Japanese imported model vehicles into your calculation?
2. Why this has not been done already?
3. How i can make sure your records are up to date so my vehicle shows as compliant as in reality my vehicle is compliant and passes the required checks.
The problem myself and consumers are facing with Japanese imports are no Certificate of Conformity has been done correctly at the import stage of the vehicle which is why DVLA will not have up to date information. Also no manufacturers in UK or EU will test these vehicles. In essence you have just blacklisted a whole market of vehicles, how will you address this problem?
I have a Japanese import Mercedes s500 L. In the UK.
Can you provide me with official Certificate of Conformity that will show the NOx levels of this car?
Or any other official manufacturer document that will show NOx levels of the vehicle. I have attached picture of VIN
I require this to properly register the vehicle for compliancy.
