MB250TD
- Dec 11, 2003
- Location
- Wales
- S124 250TD (1989); S124 E300TD (1995); S211 E320 Sport (2007)
If anyone can help before dark, I would be grateful! Car is W124 300TD. Problem following reinstalling a recharged battery. Nothing works - not even lights! I have noticed that the shorter lead from the positive battery terminal is not attached to anything, but I have not detached it! I cannot believe that a positive lead should be lying around unconnected. The lead is about 20cm long or so, and ends in an eye, as though a bolt should pass through it. I cannot see any relevant connection! The connections on top of the plastic unit sticking out from the suspension strut are all intact. Is this missing coinnection my problem and if so where does it go? Urgent help appreciated because I need to use the car to work tomorrow morning. battery definitely gives a good read out, and earth connections OK.
Many Thanks.
Many Thanks.
