URGENT ADVICE PLEASE !!!
My E240 auto (1998 model) recently is experiencing some problems which I haven't got a clue where the problem is:
1) When cold start and put gear into 'D'rive, the car won't move for a few seconds and then a big jerk then starts to move. This only happens when the engine is cold particularly in the morning.
2) Sometimes when driving coming to a traffic light (for example), the car won't move for a few seconds (and then a jerk then starts to move) after changing the gear from 'D'rive to 'N'ormal and then 'D' again.
3) After starting the car with cold engine and drives on, sometimes the gear won't change up (even its set to 'D') with the gas pedal pressed. The gear was still in 2nd gear (20 mph) but the rev is reaching 3500 to 4000 rpm. This situation sometimes lasts for a few minute and the the gear change will go back to normal.
I took it to a authorised MB garage for a check to verify the problems, they offered me a very expensive refurblished transmission replacement which they 'think' that will cure all the above problems. I am not quite convinced if this is solution as it doesn't explain why the problems only happened when the engine is cold.
Please can someone give me some ideas where the problem is. Could it be the ECU or something electronics rather than mechanical? MB also said the gear box oil is checked and OK.
Please help.
Please help.
