Borys said:I just did my valve block today but car raised on its own no problem. Replacing block will not cause much of fluid loss but we performed rodeo at the end Is the block brand new?
Borys said:Nope, used I had refurbed one on but for some reason one of the smaller solenoids was letting oil back causing right front to sink over might for about 1cm Took a risk on eBay - all good so far
Borys said:Try this item number on eBay 261962781898 My indy did it for me. One of the solenoids was badly seized when removing so we did assume refurb may not cure it 100%. It costed stupid money for seals 10 quid, so we took gamble But needed to address the issue again Still worked out better then 1400 quid from MB
Changing the o-rings on the valve blocks won't have any effect on drooping suspension since the lock valves are metal-to-metal seals. Perhaps some cleaning of the sealing surface might help, though...
261962781898
MB
