The problem is
Yea its been fine ever since that day. it was doing it all morning up untill 2.30, thought id start it up before I picked up my daughter from school to see what it did and it was perfect!
Not missed a beat every day since! If it happens again ill get it scanned, in the meantime, if anyone finds another car that has done it, it could be useful in the future!
Aidan,
As I have pretty much encountered every ABC related problem over the 8 years I have had my car I believe I have the answer to yours. DO NOT DRIVE until you check the following : Front Acceleration sensors and 1 rear acceleration sensor. There are 3 in total (2 front, 1 back). The front ones are located on the suspension top mounts, open the bonnet and you will see one on each side. Check the numbers on these sensors, there are updated sensors available. W215 had a major problem with acceleration sensors and a big recall campaign. My car decided to drop and raise itself as fast as possible at 70mph. The unexpected ride height change could make you lose control of your car as there is no way of predicting when it might happen. So drive carefully if you must drive it at all bud.
Here is the "official" explanation ;
Level changes occur intermittently and predominately after driving for extended periods. The vehicles level adjusts without obvious cause and usually quickly moves upwards or downwards and then rapidly corrects back to the specified level.
The Random Level Control is the result of contact issues on the printed circuit board of the body acceleration sensors (front left, front right and rear right-Model 215/220), in combination with the sensors heating up after an extended period of driving.
The contact issue can result in a higher internal resistance on the printed circuit board causing the sensor to output an incorrect signal, thus initiating an ABC adjustment.
For Model 215/220
Equipped with Code 487 (Active Body Control) RANDOM VEHICLE LEVEL
If the vehicle lowers randomly while driving or sporadically after stopping the vehicle, replace the body acceleration sensors with a manufacturing date greater than year 2002 wk. 01.
Note: Do not replace any other ABC suspension components.
Qty= 3; Part Name= Acceleration Sensor; Part Number= A004 542 35 18
Replace the two FRONT (left and right) Accel. Sensors for ABC and the REAR (right) Accel. Sensor for ABC.
Labour should be about 0.6 hrs for each of the two front sensors and 2.2 hrs labour for the right rear sensor. Call your dealer for parts pricing.
I bet that this is your problem. Only a STAR will pick up the codes for these sensors. Hope that helps you out.
